Cow
- Eastern Oregon
- Electrician
Siemens CU bus loadcenters and panelboards.
What was the cause.Ran into my first leviton noodle buss panel just the other day, hadda breaker that was loosing it's 'seated' connection>>>
~RJ~
What was the cause.
Sounds like a qc issue from factory if it seats on different stab but not the first onebreaker could not 'seat' on both noodle and hot properly Fred ,changed the breaker for new, same thing, abandoned the location and moved the breaker to another location.
i wasn't impressed....
~RJ~
Normally would agree until I've heard all these reports of SD mains self re-energize or failing to actually shut off when pulling handle to "off".I’m a huge fan of Square D panels. Personally I feel like they are built better.
Sent from my iPhone using Tapatalk Pro
One was on this forum https://forums.mikeholt.com/threads/god-was-with-me.2556598/I haven’t heard of those issues
Then what comes of the receipt? Menards honors it, too?HD will also match Menards 11% rebate as long as there is a Menards within the same vicinity as the HD you make the purchase at.
It’s really easy - just go online and enter your receipt number. They send you a gift card for the rebate.
that, and the fact that noodle buss configuration is essentially 30-40 more potentially bad connections under full load in that style panel(s) ~RJ~Sounds like a qc issue from factory if it seats on different stab but not the first one
