I already have wires run to the soffit locations centered over the garage door openings.
I’m planning to use the thin wafer downlights because the truss layout doesn’t allow for a recessed can housing.
The soffit material is that typical steel vented style material (not sure what it’s called).
I’m wondering the best way to cut a 6” hole in this material without crimping the edges (if I used Tin snips)?
Using a 6” hole saw scares me on this material.
I might use tin snips on the flat sections, then where there’s a corrugated divit “touch-cut” it with an angle grinder.
Any other suggestions or recommendations?
