Cutting 6” opening in soffit
Klein holesaw but let me give you more importanr info. This soffit matrial is terrible. Think about using 10" medallion for $10 each. Otherwise is will never look good.
So if this idea is so useful, why can't I find any negative hook angle hole saws? [I take it that would have the same effect.]
Cheers, Wayne
Come to think of it, in the early years I used to re-sharpen the expensive sawzall blades with a dremel. You could probably take an old
hole saw and make it into a negative hook blade pretty easily. But, as mentionened above, why bother when you can use reverse ?
