enireh
- Canyon Lake,TX
I'm thinking about doing a manual transfer switch. I have a 400 amp service with two 200 amp panels at the meter, and four sub panels one for the pool, the well, and two for the house. I want to make a generator outlet with a disconnect so when the disconnect is engaged the outlet can be used for the generator (when the power is out). I turn off both 200 amp main breakers and leave the well, and two sub panel breakers on so that will power up various circuits I leave on in emergency times like fridge, freezer, some lighting, and the well and septic system. I will be making joints at the sub panel main, and the well breaker then feeding into line side of the disconnect.
sub panel main is in one of the main panels at meter
thank you
thank you
