- San Francisco Bay Area, CA, USA
- Electrical Engineer
More states have now adopted the 2020 code.
For decades now, California has required EITHER an external service disconnect, OR it can be " inside nearest the point of entrance of the service conductors ", meaning (I assumed) the firefighters could look at the service mast and know exactly where the disconnect would be if it were inside. On most single family and duplex/triplex/quadplex homes, the meter is put on the side wall of the garage closest to the street, so putting an exterior entrance door separate from the garage door is more expensive than using a meter/main, resulting in 99% of the services I have seen here on houses built in the last 30+ years having that external disconnect means. I'm not sure when that went into effect, but it was that way since I started in the late 70s. Decades ago I did some work on some old pre-WWII homes that had basements, some of those had the service disconnect in there, making the firefighters have to go into the basement of a burning building to kill power. I always thought that was the stupidest thing in the world...
