Not sure if this should go into the grounding and bonding section.
I am working on 3 phase / 3 wire 480V delta system. I believe there is a grounded leg, but the plant doesn’t think so. I have 480V across all 3 phases. Phase A to ground 0V, the other 2 480V on one feed bus. If I go to a different bus I get 480V across all 3 phases and 277 to ground on all 3 to ground, which I normally would expect. Does this sound like a ground, as I said there is no neutral in this system.
