- San Francisco Bay Area, CA, USA
- Electrical Engineer
Let's not keep going on with red herrings here. That statement was non-sequitur from the outset because the OP said nothing about fire pumps and your subsequent statement about them only being UL listed for fire pumps is just false. I have used countless large 12 lead motors in industry for all kinds of applications; refrigeration compressors, rock crushers, airt compressors, conveyors, all kinds of pumps, you name it.... Most probably the application is in fire pump.[/FONT]
I personally abhor Wye-Delta starting because it generally causes more problems than it solves and whenever I come across them I replace them with Solid State Soft Starters if I can. Yet despite by feelings about them, they are the RV starter of choice for a LOT of OEMs simply because the starter is slightly cheaper than solid state and the OEM doesn't have to live with the long term consequences. But to say they are not used here is a ridiculous concept, as is their only having one use. So let that drop.
