How would one calculate the math? Say you needed a 3inch kick, would you just kick it 3” than do the same on the other side ?For me it would be a "do over".
I agree. Basically, you'd take a 90 degree bend and raise it up to a higher parallel plane so that it clears the other conduit by using an offset on each side of the 90 bend.With the two kicks chances are unless the kicks are huge one kick will hit the pen. Two offsets would be better, one up the other back down. I might have a photo somewhere.
I'd eyeball it. Keep in mind the kicks would not be square to the 90How to bend it would depend on the size you're working with. ½ - 1" EMT, I'd just eyeball it.
That would make sure you stay square to the 90With the two kicks chances are unless the kicks are huge one kick will hit the pen. Two offsets would be better, one up the other back down. I might have a photo somewhere.
I agree. Your second kick would roll the first one.I'd eyeball it. Keep in mind the kicks would not be square to the 90
Have to roll the bender a bit to the outside
