Romex Without Ground
Central VAC cable is typically only rated for 24V. It indeed is two conductors (no ground) only but usually fairly small gauge (I've never seen more than 16g). They also make similar cables for installation of low voltage lighting.
Yes, for the control wiring. But the POWER wiring for POWERED OUTLETS are NM.
Are you sure its not just SJW or SOOW cord?
I ain't that stupid.
I need 12 gauge.
