petersonra
 - Northern illinois
 - Semi-retired engineer
A couple years ago I talked to an HVAC guy about putting a mini-split A/C in my bedroom. It is the main room I use so I figured it would be cheaper to cool one room than the whole house.
The guy suggested several ways to run the power. One was EMT on the outside of the house either along the bottom of the vinyl siding or behind it. The other was to hide UF behind the vinyl siding. I am not real thrilled with either solution but after looking closely at the code it would not appear to me that either approach is in violation of the code.
he also suggested if I could find a 20 Amp 120 VAC circuit that I didn't mind losing that I could use that if it was more convenient. Somehow this does not seem right to me, but as best I can tell all my outlets are on 15 A circuits so is kind of a moot point.
