James L
- Kansas Cty, Mo, USA
- Electrician
Multi head system?Not the system I just installed power to. The umbilicals include refrigerant and power lines.
Yes. Single outside unit, five inside. Only the outside required a power supply.Multi head system?
I need to get around a bit moreYes. Single outside unit, five inside. Only the outside required a power supply.
Would be a long drive to northern illinois to spend a few hours in my crawl space.I"ll pull that wire thru the crawl space for you unless clearance is less than 12"
Yah these things take time, I know the feelingI discovered that in 1986 or 1987 and have yet to fix it, although several times I have thought about it.
ran into one like that not too long ago.Not the system I just installed power to. The umbilicals include refrigerant and power lines.
