Bronco9588
- Kent Island, MD
- Engineer
I have an isolation transformer serving a marina application with the applicable code being the 2020 NEC. Homeowner wants to control lighting on the downstream SDS by a switch upstream the SDS. My plan was to utilize a 120VAC relay to bridge the SDS. Anything I need to be aware between EGC, GFCI on the upstream system, or overall permissibility with regard to use of relays?
