The Burnday GAR will work
I used these to bond 3/8" OD copper tube
IMO it would need to be listed for use in that fashion on the rod.I don't think those will work. I was looking for a threaded stud to land a lug on that is not part of the clamping mechanism. Could I use one of those split bolts with the threaded stud, and put the ground rod where the wire would normally go in the split bolt?
Todd you need to be more specific in what you are trying to do. You have a ground rod-- what size is the grounding electrode conductor or are you trying to land something else on the rod?
I don't think there is any such product on the market. That would be a very, very rare installation, and there is no real market for such a connector.Need to land a lug with a 1/2" hole onto the ground rod.
Why can't you directly connect the conductor to the rod using one of the many types of mechanical clamps designed for rod to conductor connections?
OK I misunderstood. What about using the Burnday with a short pigtail to a camlock
View attachment 2555899This work?
That would be a good solution, utilizing the ground Rod coupling you could then just thread a bolt into the other end connecting your lug directly
