jmellc
- Durham, NC
- Facility Maintenance Tech. Licensed Electrician
That is a bit like the shell ground on some twist lock plugs. First make, last break.Lots of different designs could have been better.
The German Shuko ("Schutzen Kontakt" ... protective) has a recessed earth conductor -- there isn't anything that can be removed, nor any reason to. It's also completely finger safe - the plug is completely recessed inside the receptacle before the pins make contact.
