Grouch
- New York, NY
In a building there's a 30 amp fire alarm disconnect switch. 277/480 volt power wiring leaves the switch and goes to a step-down transformer about a few hundred feet away. The load side of the transformer (120/208) feeds the fire alarm panels. We have to re-reroute the 277/480 volt power wiring, so we'll need to cut and splice the wiring. is there anything in the NEC that prohibits splicing of the power wiring?
I've seen posts regarding the low voltage cabling that goes to each fire alarm device, and that can be spliced. What i'm asking about is the power wiring between the main disconnect and the fire alarm panels (with a transformer in between).
Thanks!
Thanks!
