jimbom7859
 - lockport ny
 - Controls Engineer (Industrial)
I know that they can hold 20 amps (It says right on the side), but have they been accepted by the industrial world?
			But we have residential grade and other higher grades on things like switches and receptacle devices...20 amps is 20 amps. There is no such thing as 20 dwelling amps or 20 industrial amps or 20 agricultural amps or 20 commercial amps.
One company we worked for (industrial) used them exclusively for smaller conductors and controls. I wouldn’t see a problem as long as there used in the correct manner and sized for the conductors.I know that they can hold 20 amps (It says right on the side), but have they been accepted by the industrial world?
But they aren't higher amps or a better quality amps.But we have residential grade and other higher grades on things like switches and receptacle devices...
Those, just like the term "loadcenter", are marketing terms. All of the grades meet the requirements of the product standards and there are not separate standards for "higher grade" products.But we have residential grade and other higher grades on things like switches and receptacle devices...
I hadn't heard that complaint yet. Do you have details on what may have been the cause of failure?I wouldn't use those things anywhere. Seen lots of issues with them
You sure about that or just don't like them and assuming they are inferior? Keep in mind we are talking about the "lever nuts" in this thread that have a pressure release lever for inserting/removing conductors and not the "push in" type. Also must assume they are being used within their design criteria.I wouldn't use those things anywhere. Seen lots of issues with them
They are great for control wiring, especially for terminating field devices. No messing around with wirenuts and tape.The 221 series lever nuts are fantastic. Where they really shine is with finely stranded wire like UL1015 or SO cord.
If you don't want your name being the answer to "who put these lever nuts in here?!", I would check with your higher ups to see if they are approved for use in your facility. In many situations, CYA is the most important factor.I know that they can hold 20 amps (It says right on the side), but have they been accepted by the industrial world?
Looks like they have 300 Volts marked on them. Not sure if that means L-G or L-L. If it means L-L, then maybe they aren't suitable for 480V systems?
What else do they approve of using?I can tell you that the Chief Electricians (a hard group to please) on cruise ships like and accept the Wago Lever-Loks, but will throw you off the ship if they catch you trying to use wire nuts.
