oscarcolumbo
- Florida
We just wired for a 60 amp hot tub in a lanai. We also replaced the panel with a SQ D QO. Put the GFCI breaker in the panel and a pull out disconnect at the tub. The GFCI breaker trips instantly. Disconnected the tub and it holds, connect it back and it trips. I told the home owner to call the company she bought the tub from so they can troubleshoot. A tech from the company calls me onsite and says I have to remove the GFCI and put a regular 60 amp. He says he’s done it hundreds of times, but can’t do it here cause I installed the GFCI inside the panel and not at the disconnect. The reason I installed it in the panel is cause we are having a breaker shortage cause of COVID and the only 60 amp GFCI CED had was QO. The tech said everything is fine with the tub. My question is, I’m going back to remove the QO GFCI from the panel and put it at the disconnect so I can try a different brand. I know QO is really touchy when it comes to GFCI’s and think Siemens is better with tubs or pools. Is it Siemens or Eaton? I can’t remember.
P.S. I told the home owner to NOT listen to that tech and to not have him remove the GFCI when we’re done.
