I'ved used those as well, they're good small space heat. Nice to quickly heat up a small space like a bathroom.I've also use the Marley in-wall heaters. They work fine.
CZ1512T 120V 1500/750W COS-E Wall Heater
CZ1512T 120V 1500/750W COS-E Wall Heatermorelectricheating.com
Nope. Unless your home run is going to be 200 feet and you're worried about voltage drop. Under any kind of normal conditions, you're probably looking at only 10-12 amps max @ 120vI am guessing 240v would always be better if the option is there?
They make it both ways, just be sure to check packaging as they will both look alike.OK. I'll probably go with one of the small, in-wall heaters. I am guessing 240v would always be better if the option is there?
AFCI doesn't even factor in for bathrooms - so far.OK. I'll probably go with one of the small, in-wall heaters. I am guessing 240v would always be better if the option is there?
