Small bathroom heaters
JoeNorm
WA
Any recommendations for products you have seen/used? Floor heat is not an option.
Was thinking of either a toe kick style or I have seen some wall mounted radiant towel warmer/heaters that looked cool.
thanks
I'm not a big fan of toe kick heaters anywhere somebody might stand for an extended period of time. I think a typical toe kick heater is about 1000 watts, and that gets pretty hot on the feet.
My preference would be a 1,200-1,500 watt in-wall heater across from the toilet.
Another option that is very good heat and not expensive to operate is radiant heat panel. No hot/cold spots, and can be wall or ceiling mount. They now offer one that has mirror surface that might be ideal for bathroom.
If using as an on demand heater 1000-2000watts of any style works.
If using as the main heat that is on a room thermostat and always active you don't need near that much wattage especially for most small bathrooms.
OK. I'll probably go with one of the small, in-wall heaters. I am guessing 240v would always be better if the option is there?
