r_double_u
New User
- Central Coast CA
- Maintenance Worker
I have a circuit in a panel that is running a HomeT 15amp tandem breaker. One side feeds the furnace and one side feeds a LED lighting circuit (4 cans on a dimmer) and a set of 5 plugs with a GFCI at the end of the run. Not ideal but I did not do the initial install. The LED cans function fine but I have no power to the receptacles. Story goes the tenant was running a hair dryer and flatiron on an extention cord and the circuit stopped working. All receptacles and wires have been checked but no sign of damage. Question: Could one side of the tandem breaker be damaged from over heating enough to run the smaller load of the LED but not allow the full load of both LED and receptacles to function?
