goldstar
- New Jersey
- Electrical Contractor
I need some opinions please. The mfr's directions are not specific. The HO tells me that this is a 240V, 15A unit. The data sheet states that you could use a 15 or 20A, 240V plug and receptacle. I have no problem because I could set it up either way. What concerns me is that there is a switch on the unit that switches from 120V to 240V. If the HO accidently bumps the switch, instead of making beer he'll be making toast. Also, should it be GFCI protected ?
Thanks in advance.
Thanks in advance.
