Baker
 - Pennsylvania
 - Control Technician / Licensed Electrician
Hello everyone, I have encountered an odd situation that I need some thoughts on. Hopefully this is the right topic to put this under. A friend of mine called and said that he felt a tingle when running his shower and outside faucets. I immediately said to stop and walked him through some tests and connection points to verify were good. Everything is solidly grounded and bonded. Main feed is bonded and water lines are also bonded. I had him turn main panel off and check continuity from neutral to ground and it was zero ohms. All connections were tight and in good condition. With power off he was measuring 14vac from water line to earth ground. I'm not there to see this so I was originally thinking meter reading improperly. I had him put his fluke on voltage alert and hold it up to his water lines at multiple locations and it went off detecting voltage. I had him do this on his ground rod and it did the same thing, detected voltage. This is all done with the main breaker turned off. He recently pounded wooden fence posts in the ground in the area of his underground feed. Is it possible he hit it and has voltage leaking through his ground now? I'm writing this very fast so I may have missed something. Send questions and I'll try to respond. But with main power off to the house this is the only way I can see voltage being on the water lines and ground rod.
