SG-1
- Ware Shoals, South Carolina
Considering adding a solar array & would like to be able to island during service outages. Is this an option ?
No. Hence the “anti islanding” requirementConsidering adding a solar array & would like to be able to island during service outages. Is this an option ?
Not without batteries.Considering adding a solar array & would like to be able to island during service outages. Is this an option ?
It just doesn't make sense to have a solar system and not be able to use it if the grid goes down.
Very true.Someone said: It just doesn't make sense to have a solar system and not be able to use it if the grid goes down.
But of course it does. The purpose of the vast majority of residential PV systems isn't to provide power when the grid goes down, it's to produce energy from sunlight to offset payments to the utility for electricity. Most residential PV is installed in urban areas with dependable grid power for economic reasons.
Except the planet is not in trouble.I can say I'm saving the planet too !
Well some of us have to be simple minded so the rest of us can .....Someone said: It just doesn't make sense to have a solar system and not be able to use it if the grid goes down.
Curious, my electric bills average go between $85 and $140 a month. Could I have a solar system installed that would pay me back before I die? (I'll be 69 this year)
My rate works out to somewhere between $0.11 and $0.12 per kwh.What is your electric rate?
Can you do the install yourself?
-Jon
Turn some of that 10,000 sq. ft. lawn into ground mount solar? Easier install, get the orientation you want, and less lawn to mow.My rate works out to somewhere between $0.11 and $0.12 per kwh.
I can probably figure out how to install it myself, but I doubt I have the physical capability to finish it in a reasonable amount of time. I have a difficult time cutting about 10,000 square feet of lawn with a 21" push lawn mower, I get pretty winded and tired. So, in reality, probably not.
The other issue is my roof flat area faces more east/west so I would be much better off if I had a southern direction so to max out solar generation I think I would have to install some kind of mounting to orient the panels perpendicular to the roof vs flat on the roof (maybe not, IDK).
