Carultch
- Massachusetts
I read through this... great article, thank you. is there a similar article for three phase inverters? the only one i can find is 3 phase but with the Canadian Electrical Code... looking for three phase with the NEC.... nothing on Google that I can find. If nothing i can try to call SolarEdge tomorrow.
The working principles of the DC side of the system are still the same for SolarEdge's three phase inverters as they are for their single phase counterparts. There are different specs and constraints that apply, but the fundamentals of the DC design are still the same. The 277/480V inverters that require you to use 1000V strings, while the 120/208V inverters are still 600V and less on their input. The 3-phase inverters also introduce the possibility of using dual-module optimizers. Expect them to be used on 277/480V designs, but don't expect them to be possible to use on most 120/208V designs.
The AC side of the system is designed exactly the same as the AC side for any other three phase PV inverter. If you are new to three phase, I'd recommend researching some of the fundamentals of 3-phase circuits. Some questions to get you started:
1. What is the meaning of the term "phase" in three-phase?
2. What is the ratio between the phase-to-phase voltage and the phase-to-neutral voltage? What is a geometric representation for why it is this ratio?
3. Given the phase-to-phase voltage and equal current on all three lines, and unity power factor, how do you calculate the kVA and kW?
4. Given equal currents on all 3 phase conductors, is there any current on the neutral? Given different currents on the three phase conductors, how would you calculate current on the neutral? What purpose does the neutral serve in a three phase circuit?
5. We talk about WYE and DELTA when discussing three-phase, which refers to the arrangement of the windings in a transformer. In general, this called the topology or the vector group. What do WYE and DELTA mean, and how did the two kinds of topologies get their names?
6. Can I connect a delta topology transformer primary, on a grid that starts with a wye topology? How about vice-versa? What is the essential difference between a grid formed by a transformer's wye secondary, and a transformer's delta secondary?
