Sigh.......
electrofelon
Cherry Valley NY, Seattle, WA
Frowny face :(
The quick brown fox took the path of least resistance over the lazy dog.........................................................................
I’m sorry, but I couldn’t help but notice your open tabs on the screenshot..
You have 8,007 UNREAD emails???
The Ground. It has so many magical properties we should all take a moment of silence in reverence to it daily.
I spent the last four days in an aircraft hangar core drilling eight inch holes through a two foot thick concrete floor in order to drive ten foot ground rods so that an airplane can be grounded while it's being worked on.
:unsure: I guess so......just promise you wont go on ebay and by that breaker out from under me 😡
I won’t..
trying to quit doing any jobs. It’s hard when people are basically begging for electricians now.
I wouldn’t even look at a job that took a panel change or add.
But isn’t that for static grounding for fueling?
They use rather higher flow rates for fueling aircraft.
When you fuel your car you should touch bare metal with your hand prior to sticking the fuel nozzle into the filler.
-Jon
