electricsimmons
300.15 ex: B, E , J
Issue with inspector on recessed cans and wafer lights: see links for specs of the products I use.
https://tamliteusa.com/spec_sheets/CLY6-CCTA-72-DYNAGEN.pdf
https://tamliteusa.com/spec_sheets/ROUGH-HB-44-DYNAGEN.pdf
When roughing our houses, we install the housing for these lights and run our wires.
Once we go back and trim the house we connect wires to cans/wafers.
I am being failed for wire nuts not being placed on the wires in the housing at rough inspection. between the rough and the trim phases.
The way I'm interpreting the code is that if I'm using this type of housing, I do not have to wire nut these.
