jutasi
- Cincinnati, OH
Many solar installs exceed the backfeed rule for breaker panels, and thus require a client side line tap that connects to a FUSED AC DISCONNECT SWITCH.
I do inspection work for a few solar companies and one company has a crew that consistently connects the NEUTRAL of the FUSED AC DISCONNECT SWITCH directly to EARTH GROUND with the traditional #6 bare copper wire. It is my opinion that only the GROUND connection of the FUSED AC DISCONNECT SWITCH should be connected to Earth ground. Which is correct? Ground terminal to ground, or NEUTRAL to ground?
