Grouch
- New York, NY
I found this article on how the power factor of an inverter can affect the power factor of the grid. It's from 2015, so I'm assuming this is mostly accurate to this day?
If you go to page 3 it has an explanation (and nice pictures) on how a unity power factor inverter only delivers real power (watts) to a building. That decreases the real watts that the utility delivers; however, the reactive power, Vars, is still being delivered at the same amount to the building. Since the real power being delivered by the utility has decreased, the total apparent power has also decreased. and when you divide the watts by the apparent power, the power factor in the example on page 3 went down to 0.77.
My questions are:
1. For small residential projects... are most inverters only available at unity power factor?
2. Do larger projects, such as commercial, offer inverters where you can modify the inverter power factor, so the inverter can deliver both real and reactive power? That way it won't affect the utility power factor as much.
3. If you click on this inverter by Solaredge, it shows a power factor range between 0.85 and 1 for both models. Does that imply that the power factor on these inverters is manually adjustable?
Thanks again.
My questions are:
Thanks again.
