Phillip Land
- Rome, Ga, US
Hi,
So I have a problem that I need help with. I am going to layout the installation as I saw it and leave out my attempts to correct problem.
New single family dwelling unit
200 amp service with main breaker outside in combination meter/disconnect can
* 2 ground rods with #6 copper to neutral/ground
buss in outside disconnect
* 40 circuit interior panel fed with 4/0 4-wire al
ser feeder in garage
* neutrals and eq grounds separated in panel
* 2 eq ground bars connected with #4 copper
looping around panel (I don't know why the
can wasn't sufficient)
* #4 copper from rebar ground in garage to eq
ground bar in inside panel
* #8 copper from gas manifold in crawlspace to
neutral bar in panel
Problem:
Multiple Afci breakers randomly trip every couple of months for no apparent reason, even on sunny days
I have tried a few solutions that did not correct problem
Any suggestions?
Problem:
Any suggestions?
