LarryFine
- Henrico County, VA
- Electrical Contractor
Last service call I had for one was solved by swapping the tripping one with another one from the same panel.
Have you ever had any success solving any other electrical problem using the same method?Last service call I had for one was solved by swapping the tripping one with another one from the same panel.
Swapping parts alone doesn't always solve issues, but it's a valuable troubleshooting tool.Have you ever had any success solving any other electrical problem using the same method?
Swapping parts is a valuable troubleshooting tool, but simply moving one breaker to another position in the panel should not be the solution to an electrical problem because that problem should not exist and only exists with AFCI breakers.Swapping parts alone doesn't always solve issues, but it's a valuable troubleshooting tool.
Had this not worked, I still would have found out whether the problem was the breaker or the load.
In my example above, it worked because the problem happened to be the combination.
I mostly do commercial construction so my exposure to AFCIs is limited. In 2010 and 2011 I wired two custom homes and my experience then is what completely soured me on AFCIs.How many AFCi issues to you get per month on clean circuits that you / your company installed?
VS calls do you get like the OP got Phillip got, where he is asked to troubleshoot a presumably newer house?
Not being snarky just genuinely interested.
I am furious about the AFCI thing, particularly the part you mention about the manufacturers using the public and EC's as their beta testers. Some people need to go to jail for that - Im dead serious. I have been to jail for much less. I remember when I first started needing to use AFCI's in the early 2000's, and they were awful. Like pretty much any vacuum or sawzall would trip them almost immediately. I remember having to come back at the very end of the job to put the AFCI's in because I didnt want all the trades people to not have power using their tools.I mostly do commercial construction so my exposure to AFCIs is limited. In 2010 and 2011 I wired two custom homes and my experience then is what completely soured me on AFCIs.
Prior to that I had troubleshot a lot of AFCI problems and always found a wiring error to be the problem. I kept saying, "All you guys complaining about arc faults need to learn how to wire or troubleshoot better".
The first house had AFCI problems every time the carpenters plugged in their new saw that had a soft start. I posted about it here asking if anyone knew why a power tool with a soft start would trip an AFCI. Sq D Homeline breakers.
Second house was GE breakers and the same thing would happen with certain power tools. Then after the owner's moved in I got some calls because their tv and vacuum would sometimes trip the breaker. Common thread was electronics were involved. I got a hold of someone at GE tech support and he admitted that certain loads caused a false trip and he sent me a box of brand new fresh batch of updated breakers that were better than last years model. I posted about that on here too.
It was then I realized that a lot of complaints about nuisance trips were legitimate and changed my opinion about AFCIs completely. Sometime soon after that Electrical Contractor magazine ran an article where the electrical manufactures admitted that they were using the general public as beta testers for their technology.
Yeah thats a pretty good sample size. I was going to say that I am a one man show and do about 2/3 commercial these days. What do the AFCI service calls end up being typically?Interesting, I am guessing our residential guys install an average of ~50 AFCI's a month, for perhaps the last 20 years.
I'd say the calls we get to the service department about AFCI's are almost never for jobs we did.
And there is probably and average one AFCI service call every two months say ~6 a year.
Because of the completely botched and felonious way afcis were introduced,. I think they're effectiveness is permanently doomed (even if we grant that they work now which I'm still not convinced). For example, consider a scenario where there is a damaged wire. Nail, rodent damage etc and an actual arc fault and the breaker trips. Think about it, what is going to happen here? First it will probably be assumed to be a nuisance trip, and besides, really, who is going to go start cutting a zillion holes in a finished house to try and find the problem? Most likely the breaker will get swapped with a regular breaker problem "solved".These AFCI's are good at making otherwise good professionals attain that kind of label. Meanwhile the handyman that is cheaper replaces the AFCI with a standard breaker and it never trips again - who is the saint in the owners eyes?![]()
It is difficult to sustain an arc at only 120 volts as well. You generally need to be feeding material into the arc or it will self extinguish, just like you do when welding with an arc welder you either keep feeding wire into the arc to sustain it with a wire welder or keep moving the rod closer as it is consumed with a rod type electrode.Because of the completely botched and felonious way afcis were introduced,. I think they're effectiveness is permanently doomed (even if we grant that they work now which I'm still not convinced). For example, consider a scenario where there is a damaged wire. Nail, rodent damage etc and an actual arc fault and the breaker trips. Think about it, what is going to happen here? First it will probably be assumed to be a nuisance trip, and besides, really, who is going to go start cutting a zillion holes in a finished house to try and find the problem? Most likely the breaker will get swapped with a regular breaker problem "solved".
I was going to say similar. That is party how I come to my unscientific conclusion that most AFCI issues are wiring problems. Just from what I have seen, and the number of electricians I have met that tie all neutrals together in multi circuit switch box.........sloppy connections, knicked wires......I would say a significant amount of residential new wiring is roped and stapled by untrained unqualified persons.
I think it sort of comes down to inspections and enforcement as well though.I was going to say similar. That is party how I come to my unscientific conclusion that most AFCI issues are wiring problems. Just from what I have seen, and the number of electricians I have met that tie all neutrals together in multi circuit switch box.........sloppy connections, knicked wires......
I'd say its waaaay more than commercial by an order of magnitude.Those small add a circuit projects in a dwelling may not get permits
I am talking about permitted new homes, in my state its legal for a 'home owner' to permit and install there own wiring.
Many times the 'owner builder' pulls the permit but others do most of the work.
A significant amount of new homes are built this way.
They are supposed to live in the house for two years before they sell it.
But there is zero enforcement of that.
I have seen this in many states for many years.
Then there is the house flippers, they buy a house therefor are the 'owner' claim they live there do all the work DIY then sell the house.
They do panel swaps, kitchen remodels, install can lighting, swap out appliances etc. etc.
Or they hire cash labor to do it for them.
Then you have the landlords that use their uncle, a property maintenance company, or DIY, to do all their electrical.
Or the best is when they trade the tenant for electrical labor.
the list goes on.
Commercial places here get visits by OSHA and fire marshal inspections, plus they need to pull a permit when a store or occupancy changes.
And are usually way to busy to to their own work.
It used to be somewhat that way with homeowners permits. Inspectors were getting tired of essentially being a "how to" source and walking these people through the entire project. Correction notice fees apparently wasn't good enough to sway them either, at least until they got to a point they eventually hired someone licensed to finish what they started. I hated stepping in on those and tried to avoid it.Thats good to here, its defiantly not the case here, home owners are given a permit easy peazy, just need your name on the deed.
A few years ago had a nice customer with a really nice commercial kitchen we did.
He called and offered all the GFCI's we put in back, as he had swapped them out to regular receptacles.
He later got fined something outrageous by OSHA, I cant remember the amount but it was in the thousands,
we had to go put them all back in, fix some other stuff he did and pull another permit of course.
