Might as well run mc.It is not specified in the code. It is up to the inspector to decide if it is subject to physical damage which is open to interpretation. Some say above 8'. Some say higher. Some say it is always subject to damage. If you want to mitigate that, you could install wooden guard boards on either side and he'd probably consider it protected from damage. Or sleeve it. Or run it between some pipes.
To state the obvious, if the ceiling is sheetrocked, staples will not hold.How high must a garage celling be to staple romax to it ? ( 2011 code) ???????????????????????????????????????????????????????????????????????
Sheeting staples in an air nailerTo state the obvious, if the ceiling is sheetrocked, staples will not hold.
If the ceiling is 'rocked, the wire should be fished if not in a raceway.To state the obvious, if the ceiling is sheetrocked, staples will not hold.
In some places MC is cheaper.What is the cost now for 12-2 MC and NM?
Paid 150 today tor 12-2 AC (bx)
Sent from my SM-G986U using Tapatalk
There are lots of people that still call it BX. I don't see AC or BX here either, just MC. But they still call it that!Did you really buy AC and not MC.... I have not seen AC for sale anywhere in years
Yes absolutely, very commonly sold by most supply houses through NYC . Good old steel AC-90 is what we wire majority of our homes with hereDid you really buy AC and not MC.... I have not seen AC for sale anywhere in years
