Lets say you have a generator and you need the generator to have a floating neutral. unfortunately the generator came with the neutral being bonded to the frame thus making it intended to be used as a separately derived system. No problem, you can just open up the generator and unbond the neutral from the frame, easy as that... BUT what if the manufacturer tells you you shouldn't do it? Would it be a code violation if you modify the generator?
NEC tells you to always follow manufacturer, so I honestly don't know if I just answered my own question here. People modify the neutral at the generator all the time so I want to know what people's take is on this.
