- NE Nebraska
- EC
A transfer switch is nothing more than a "double throw switch" that connects a common terminal to the load served and you operate the switch so that you connect to either the utility or to the standby generator. Is designed so that you can never connect simultaneously to both sources.I'm not an expert obviously regarding Transfer switch products, but I believe there are separate transfer switches and combination transfer switches.
Without looking it up, some units I believe are incorporated into the main panel, only allowing one position or the other to feed the panels breaker bussing whereas I've also seen others that are simply a secondary enclosure which separately connect into an existing main panel enclosure, many times a lug block is used or a secondary over current protection is used to regulate the potential from the generator onto the breaker buss.
The "combination" you mention is just a more advanced switch that maybe has one or more of the following: service disconnecting means incorporated, load center incorporated, automatic transferring components incorporated. Simple manual transfer switch is typically nothing more than a double throw switch.
