what a mess ! (nightmare electrical situation at old house)
I don't think a toner widget will help identify the noodles.
Put a tone on the cable, then go see which neutral it's on ? (I already know which hot, having mapped the breakers). Or because the neutrals tend to be all jammed together in the gutter, difficult or impossible to tell which one is toning ?
Back to OP (referencing points #2 and #3) ... what is the point of a MWBC, if you immediately (just inside the crawlspace from the outside load center) split it into two /2 cables ? To lessen the fill in the PVC nipple ? They didn't do it for all the MWBCs, but with several of them.
Yes, not worth it. J boxes and labor must have been low back them.
Evidently j-boxes were expensive then too :) I say this, because this trick (splitting the MWBC into two /2 cables) was done twice on one j-box. One cheap plastic 18 cu-in j-box. That's right, there were fourteen 12awg wires, plus ground, in one of those little boxes.
