I assume there are no local amendments to the 2020 nec , am I right?The test is based on the NEC and tests your ability to navigate the code book. The more you know about the structure of the code and your familiarity with the most common sections the more time you have to look up the references for the more obscure questions.
That's probably true now, but the only reason I took the test was to see how hard it was.the only reason to get a masters in Colorado is if you want to be an electrical contractor and be able to pull permits.
Well you also get to help out the state by generously pay a bigger renewal fee every cycle.That's probably true now, but the only reason I took the test was to see how hard it was.![]()
