Colorado master electrician test
darekelec
nyc
My friend is preparing for the above test. He said its based on 2020 NEC and I would like to ask if there are amendment he has to learn. Is electrical theory on the test?
The test is based on the NEC and tests your ability to navigate the code book. The more you know about the structure of the code and your familiarity with the most common sections the more time you have to look up the references for the more obscure questions.
I assume there are no local amendments to the 2020 nec , am I right?
What would be a good source of material to study for the exam? Mike holt 2020 comprehensive library or is it overkill and other book would suffice?
It's not that different than the journeyman's exam. Whatever guide your friend used for that should be adequate. Mike's study guides are excellent. The exam prep is enough, you don't need the guide to the nec, electrical theory, grounding and bonding materials to pass the test.
We live in nyc and he is moving to Colorado and wants to pass the master test . Is it the case that first he has to pass journeyman test ?
The level of nec knowledge is pretty low here but after studying our other friend passed master test. He used
I'm licensed in Colorado but I was born in the state so I'm not sure what happens when you move here, but I'd wager you would need to get a journeyman's first either through reciprocity or taking the test. However, the only reason to get a masters in Colorado is if you want to be an electrical contractor and be able to pull permits.
