- NE Nebraska
- EC
Is smart to turn it off before working on it.Lots of things affect the body's ability to carry current....with skin moisture/sweat being one of the heavy hitters, literally. Tell your employee to stop being stupid and turn stuff off before he touches it. That's just dumb.
Also is smart to understand why it sometimes doesn't shock you.
In wood constructed building most the time you are not grounded unless you are in contact with some grounded object within the building, like an appliance frame, or the yoke of a device you happen to be working on. But if standing on wood/carpet/other non metallic floor covering and simply touch the "hot conductor" with just one hand, normally there is no low enough resistance path that you will have enough current pass through you to feel it, that is simple Ohm's law stuff there. What does get people that get too confident with this is becoming grounded somewhere and not knowing it, or getting in a path, touch the incoming "hot" and also touch the outgoing "hot" lead to an open switch and if there is a connected load you still get shocked because you put yourself in the circuit path.
