richardelectric
- Marcellus, Michigan
- Journeyman Electrician
Great background music...
Whoa. I didn't realize that version of the video doesn't have the original soundtrack.Great background music...
Okay. Thank you for the grace of time. Here's my thinking.I'm not following the "intentional ground" concept. If you are grounded, and touch the hot conductor, you are going to get hit whether or not the neutral is connected. The connection status of the neutral will not affect anything. What it does do is provide a big grounded object right where you are working so I cut that first and tie it out of my way
I am somewhat confused by your terminology. I still am not completely clear on what you mean by "intentional ground". Because you are calling ground, intentional ground, and neutral all the same thing,. I believe you are using these terms to refer to one "side" of a circuit or the "return" path that completes a circuit. Similar to how we refer to the negative side of an automobile electrical system as ground. Is that correct? May I ask what industry you are involved in? Just curious because of the terminology seems like you're maybe in a different industry than premise wiring.Okay. Thank you for the grace of time. Here's my thinking.
Real World Example
Have you ever walked up to a metal case and received a shock when you grabbed the door handle? I sure have, so I touch metal cases with the back of my hand even today before I reach for the door handle. If you ever experienced this event, why did you get shocked? The short answer, for some reason, you were a better ground (neutral) than the intentional ground of the circuit.
Are you talking about a static shock, or continuous current?Have you ever walked up to a metal case and received a shock when you grabbed the door handle? I sure have, so I touch metal cases with the back of my hand even today before I reach for the door handle. If you ever experienced this event, why did you get shocked? The short answer, for some reason, you were a better ground (neutral) than the intentional ground of the circuit.
A continuous current.Are you talking about a static shock, or continuous current?
120 if solid connection will hurt for days too. And tachycardia. Hand to elbow on ceiling grid. A simple slip of the conductors while working to make connection was all it took. NEVER will work "live" again. Or I will glove up.277 was my worst hit ever.
It’s funny now but your right! Hand in a vice!
I swear I hurt for a couple of days and was scared for a year…
You glove up when make/break the service drop connection?For my service drop example do you see how breaking the neutral first and moving it out of the way is safer? Note I am assuming we have access to the service disconnect or pull the meter so we know there are no loads connected making the neutral energized.
In summary, to be blunt, your "break the neutral last, make the neutral first". Philosophy is not always true. It depends on the situation. You can't make a blanket statement that that is always safer.
Got minor jolt from metal door knob on a trailer. Found the metal siding of trailer to literal earth metered 120V. Door knob had about 30V.Have you ever walked up to a metal case and received a shock when you grabbed the door handle? I sure have, so I touch metal cases with the back of my hand even today before I reach for the door handle. If you ever experienced this event, why did you get shocked? The short answer, for some reason, you were a better ground (neutral) than the intentional ground of the circuit.
I work in the electrical field. Perhaps our terminology is different because of location. Let's say we are dealing with a single-phase 120-volt circuit. I think we agree that it takes two conductors to get this circuit to work: (1) an ungrounded conductor (hot) and (2) a grounded conductor. Do you consider that ungrounded conductor a neutral? Please refer to the NEC Article 100 terms. Using Ohms Law, would you show me why the concept does not apply to parallel circuits? I am willing to consider at your thinking.I am somewhat confused by your terminology. I still am not completely clear on what you mean by "intentional ground". Because you are calling ground, intentional ground, and neutral all the same thing,. I believe you are using these terms to refer to one "side" of a circuit or the "return" path that completes a circuit. Similar to how we refer to the negative side of an automobile electrical system as ground. Is that correct? May I ask what industry you are involved in? Just curious because of the terminology seems like you're maybe in a different industry than premise wiring.
I also find the example in your attachment mostly irrelevant because it is referring to series circuits which essentially do not exist in premise wiring. In the attachment, yes I agree placing a jumper over one of the resistors would make the potential between those points essentially zero, but that doesn't really make any sense anyway because you can't just jumper one of the resistors with resistors in series as you will increase the voltage drop across and current thru of the other resistors.
Okay, I think what you are saying is one can get shocked by touching an open neutral (where there are loads connected between it and the ungrounded conductor of course) and a return path to the source. Yes of course that happens, I acknowledged it previously and said in the case of the four square box that if you break the neutral first and then the hot you are dealing with two live connections, where if you break the hot first you are only dealing with one live connection. But even if you break the neutral first, the potential of the ungrounded conductor to ground is still what it is and does not change (sorry if that is not what you are saying, seems like it was).
Yikes!Got minor jolt from metal door knob on a trailer. Found the metal siding of trailer to literal earth metered 120V. Door knob had about 30V.
Ah, this adds context. Now to respond to:A continuous current.
Not necessarily a better ground (pathway), merely an additional one, in parallel with any others. Not only will a new, lower-impedance pathway conduct current inversely proportionate to its impedance, any existing parallel pathway already there will continue to carry the current it already was . . .Have you ever walked up to a metal case and received a shock when you grabbed the door handle? I sure have, so I touch metal cases with the back of my hand even today before I reach for the door handle. If you ever experienced this event, why did you get shocked? The short answer, for some reason, you were a better ground (neutral) than the intentional ground of the circuit.
I should have said "not necessarily a better current pathway . . ."The person was not a better current pathway, just an unfortunate additional one.
And it should be noted that the human body is far from a "good" current pathway. If we assume a typical 120 volt shock will result in a few milliamps of current flow,. Let's say about 4ma, that is 30,000 ohms.I should have said "not necessarily a better current pathway . . ."
Two short stories:Got minor jolt from metal door knob on a trailer. Found the metal siding of trailer to literal earth metered 120V. Door knob had about 30V.
There is a difference between disconnecting a grounded conductor and disconnecting a conductor that has a downstream grounding connection.I'm not following the "intentional ground" concept. If you are grounded, and touch the hot conductor, you are going to get hit whether or not the neutral is connected. The connection status of the neutral will not affect anything. What it does do is provide a big grounded object right where you are working so I cut that first and tie it out of my way
Also consider that because of voltage drop, a grounded conductor carrying current will have a rise in volts over "earth". Often times not enough to be noticeable by simple touching, but anytime there is current there is a voltage drop across the conductor. With a MGN utility supply even an unloaded grounded service conductor still will typically have some small voltage to earth because of voltage drop on the primary neutral it is also bonded to.I work in the electrical field. Perhaps our terminology is different because of location. Let's say we are dealing with a single-phase 120-volt circuit. I think we agree that it takes two conductors to get this circuit to work: (1) an ungrounded conductor (hot) and (2) a grounded conductor. Do you consider that ungrounded conductor a neutral? Please refer to the NEC Article 100 terms. Using Ohms Law, would you show me why the concept does not apply to parallel circuits? I am willing to consider at your thinking.
