RatherBeFishin
- New York
- Electrical apprentice
Not trying to promote hot work, but one sometimes tailors the order of things to the needs of the application. Been times I maybe didn't connect the EGC to the yoke of a device until it is the last thing left, that way you not grabbing something grounded while working with the ungrounded conductors.
@kwired this is how i so hot devices as well,Not trying to promote hot work, but one sometimes tailors the order of things to the needs of the application. Been times I maybe didn't connect the EGC to the yoke of a device until it is the last thing left, that way you not grabbing something grounded while working with the ungrounded conductors.
Although was trained to make up ground first then neutral, then hot. The problem with that is I’ve been shocked by holding the device by the yoke with one hand and accidentally touching my screwdriver shaft while tightening the hot. That breaker won’t trip and you’ll just get shocked every time like that.
Or he’s a question for you if you do the ground first method and have your one hand holding the yoke and other hand holding the insulation of the hot wire while landing it in on the pin and you hit the yoke, that breaker should trip but wouldn’t you also get whacked at that same moment by touching ground with one hand?
