Hi All.
Great forum! I was trying to find an answer to an issue today and found your forum.
I work as a mechanic for a company that uses belt conveyors to move product.
When the conveyors were overwhelmed today with a lot of product, I saw building supervisors (who are neither mechanics or electricians) cycling off MCC bucket disconnects to control different sections of the belts.
It was to my understanding that this is unsafe. These buckets control 480v, 3 hp motors. I am in belief that the control stations should be utilized, followed by using the regular disconnects as a second choice, followed last by using the knife switch at the actual mcc.
I know that our motor controls centers haven't been tested/rated so they do not have any type of rating info instructing what level of ppe to wear. Supervisors here just wear street clothing.
I know why they do this. If they use the control station, it shuts down All of the belts. If they use a disconnect, they can cycle off sections and let product run out from a jammed area.
Nonetheless, it seemed like the most dangerous choice was made to do this at the bucket versus a disconnect.
From what I've read, it looks like an arc flash Can also take place at a disconnect but is it More likely to occur at a bucket?
To be clear, they are stopping and starting loaded belts abruptly by opening and closing disconnects manually, engaging and re-engaging the live load to the motor.
It's not my area of expertise so I definitely wanted to ask you all for some help.
If I'm wrong or over worried, no problem. If they are doing something that will surely lead to an injury, I'd like to come up with a plan to better help them going forward.
Thanks!
Thanks!
