- New Jersey
- Journeyman Electrician (retired)
We might rig stuff up the elevator shaft if that is feasible.
We'll you would need a rigger for that?We might rig stuff up the elevator shaft if that is feasible.
Not necessarily, we set up our own chain fall and lift the equipment ourselves. If you use a motorized fall and there is an operating engineer on the job they will claim it as their work and you'll have to pay him to push the button.We'll you would need a rigger for that?
Have new construction of small building where gear is going up to the 2nd floor which is about 40'. It's in a room on perimeter so it has exterior wall.
I guess it obviously matters how big the sections of gear will be. But would there be another way to get them in other than hiring a rigger or crane?
Thanks.
I cant imagine the practicality of designing a switch gear system that cannot be removed during the finish stage, in the event such a time should occur. Granted it should last for decades, it just seems unwise.
Yup. Took out a three section switchboard, out of an office building. Sawzalled it into pieces.....If for some reason it absolutely had to come out you would disassemble it or cut it into pieces.
