That would be a lot of light. The brights lights in my house are 15W and I use these for my wife's painting projects.If the lights good for 75 watts that should be the controlling factor. I would think.
If I want to use a led that uses 75 watts.
still same wattage use
I would agree with that.I understand that, if the led is listed for use in enclosed fixture than the fixture wattage should not matter
It might not be about the wattage, it might be about the heat generated. The LED driver, particularly really close to the screw base, can be really hot
It's not the LED that makes the heat, it's the driver components. And they can get really hot.If an LED delivers the same lumens (that's what 'equivalent' is supposed to mean here) for roughly 8 times less watts, then it's generating less than 1/7th of the heat of an incandescent.
My default preference in lighting levels is "surgical suite", but a 75 watt LED might be a tad excessive.That would be a lot of light. The brights lights in my house are 15W and I use these for my wife's painting projects.
Are your bulbs rated for enclosed fixture if not that could be why the short life spanMy experience indicates that OPs rating question is due to the electronics getting to hot. I have a flush mount enclosed fixture with horizonal lamp sockets rated for 2 60 watt incandescent lamps. I use Phillips LED 60 watt equivalent lamps and they always have a much shorter life than I get in other fixtures.
The bulb as a whole has a wattage rating about 1/8th of a incandescent. Whatever percentage of the watts are turned into heat are included in that wattage.It's not the LED that makes the heat, it's the driver components. And they can get really hot.
Yes, but the driver components have to be cooled by conduction into the base. Someone likely calculated the thermal conductivity, expected maximum ambient temperature, and then decided how hot they wanted it to get.The bulb as a whole has a wattage rating about 1/8th of a incandescent. Whatever percentage of the watts are turned into heat are included in that wattage.
