goldstar
- New Jersey
- Electrical Contractor
An HVAC contractor friend of mine told me yesterday that an EI failed his AC condenser replacement because the existing10/2 NM cable from the breaker panel to the existing 30A pull-out disconnect did not have the white wire re-identified inside the disconnect. The contractor installed a new, pre-manufactured whip from the disconnect to the AC unit and it had # 10 B-R-G wires in it. Personally speaking, the only time I would re-identify this wire was if I were contracted to upgrade the electric service. I would use a magic marker and re-identify that white wire but I don't believe I'm required by Code to do so. I thought re-identification was required on # 4 only. Am I wrong ? Was the EI wrong in citing the HVAC contractor ?
