From what I understand, If a panel is free standing outside at the pool equipment location, ground rods are not suggested or required.
I looked at an old Federal Pacific panel feeding a pool pump yesterday that needs replacing. It's a rusted exterior panel (fed with 30 amps) that looks like it was outside free standing by the filter then years later someone built a small shed around it to enclose the filter and have an area to store garden tools.
The panel is low sticking out of the floor located in the middle of the shed by the equipment as if there was no shed..
There are a couple of lights installed in the shed with a switch.
Question is, electrically what changed between having the panel free standing by some pool equipment outside and free standing by some pool equipment with four walls and a roof around it?
Why would four walls and a roof warrant adding ground rods?
Thank you.
Thank you.
