BMS-Electrician
- Los Angeles
- Electrician
Customer is setting up a new manufacturing facility with 8 Chinese machines. They all have internal breakers and are all 380V/3P/4W on the nameplate. The largest is 6kw and the smallest .5kw. total kw of all machines is 21.6. (machines are mostly cutting/drilling for making indoor window shutters). Main panel (400A 460V) is about 120' to the nearest machine and 250 to the farthest machine.
Do I need to run separate circuit to each machine (sub panel near machines) and install buck-boost at each machine or is there a more cost effective way to go about this?
Can I run one circuit through a 1.5kva buck-boost set up and split it to all machines?
