Hint. My answer was based on only two resistors.I see that , what answer did you come up with?
The other resistors are bypassed because there in a path around them.I'm really just learn how to do solve the the question, so if someone could teach me how and why we are only using two resistors
What is the formula for resistance of parallel loads.The book says the answer is 500 watts, please explain how they got that.
I'll give you one hint. Anytime you have two equal resisters in parallel you can solve without using the formula as the answer would be half the value of the resisters. Example: (1) 40ohm resister in parallel with another 40ohm resister would be 20ohms.Thats why I am asking the question? Can someone please just tell me how to do it? Thanks
Your uglys book will have some actual examples showing the math.Yes I know all about that , what I didn't know is how to find total resistance of parallel loads. The equation made no sense to me , now I understand it. Thanks for the help
Going to purchase an uglys book immediately, thanksYour uglys book will have some actual examples showing the math.
