You don't have to get Ugly about it!Dang you beat me to it...
No. Imagine or draw the circuit with all switches closed instead of open as shown.Total resistance of the line diagram 50 ohms?
NopeTotal resistance of the line diagram 50 ohms?
Use the formula in the "pie" chart for power, I²R. You know the current is 10A, if the resistance was 50ohms, the answer would be 5000W. 5000 was not one of the choices for the answer.Total resistance of the line diagram 50 ohms?
So this is the best explanation I have gotten, do you know of a video or anything I can watch that teaches this. People have to understand my bigger problem is I can't find anything that teaches this. The book says the answer is 500 watts.With all switches closed, SW3 effectively shorts the 5 and 20 ohm resistors. The only resistance in the circuit is therefore the two parallel 10 ohm resistors. The quick calculation for parallel resistors is their product over their sum. It simplifies further when the resistors have the same ohmic value. The total resistance is the resistor value divided by two. Here, total circuit resistance is 5 ohms. Using Ohm's Law Power = I X I X R =500 watts. Basic DC circuit analysis (from 35 years ago I might add)
Doesn't resistance usually show a load?If all switches are closed, current will only flow through the two 10 ohms paths. SW3 shorts out all other paths.
Shortcut for equal parallel resistances paths is to divide in half.
V=I*R
Voltage across both 10 ohms resistors (5 ohms combined) is 10A * 5 Ohms = 50.
P=VI
Power dropped across both 10 ohm resistors is 50V * 10A = 500W
The problem is a test of your knowledge of Ohm’s law. Google search will provide plenty of instructional information. The switches in the problem are really just a distraction. A basic, methodical way to solve the problem is to re-draw the circuit without all of the elements that are made irrelevant when the switches are closed. Then apply Ohm’s law to the resulting, sim
I am always amazed at how poorly electrician apprentices are taught the really basic stuff about electricity. This should have been something the op figured out in his head in about ten seconds.
The other issue that just makes me crazy is how few electricians can actually read electrical drawings and understand them.
plified circuit
Ok, man last time I ask a question on here , thanks for your input.I am always amazed at how poorly electrician apprentices are taught the really basic stuff about electricity. This should have been something the op figured out in his head in about ten seconds.
LolOh, well. So much for having the OP figure it out for himself.![]()
I was hoping you would see that the only components that would contribute to the question as asked were the two 10-ohm resistors in parallel. Then you would have the two variables, 5 ohms and 10 amps, and use them to determine that the formula to use would be:
The only main issue I was having was getting the total ohms. I thought all resistors represented a load like a light bulb.The whole purpose of that exercise, once you get the resistance, is to figure out what value you're looking for (P in this case), what values you know (I and R), and what formula you need to use to get there.
I prefer the two-step method, using E = I x R and P = E x I, over using the chart that uses squares and square roots, because I can remember the two simple formulae and use them in my head without a calculator.
But, this pie chart does show how to determine the value you're seeking, which will be one of the four values in the center circle, and then knowing which two values you have will tell you which formula to use.
Basically, yes. Bulbs in parallel pass more current than one will, while bulbs in series pass less current than one will.The only main issue I was having was getting the total ohms. I thought all resistors represented a load like a light bulb.
I'm not sure I understand what you are saying, but yes, resistors are normally a load. The exceptions areThe only main issue I was having was getting the total ohms. I thought all resistors represented a load like a light bulb.
