Jimmy80521
- Nebraska
I started my apprenticeship in 1998, and have worked with many electricians but the other day I had a guy say that if you have to work on an energized circuit you should disconnect the neutral 1st, hot 2nd, then ground. I was always taught when putting it together you go ground, neutral, hot, and taking it apart hot, neutral, ground. Anyone else heard of the neutral first, or last in connection or disconnection of a circuit?
