HamElec
New User
- Pennsylvania
- Electrician
So I have a customer that wants electric heat in her movie room that is being built in her basement. I took the dimensions of the room and its 408 Sq Ft at 10 watts per sq ft comes out to 4080w of heat. She would like to use the in wall fan forced heaters. I was going to get two, 2000w heaters and put one on either side of the room. I know this is too much to put on a 20a circuit, so I would like to run 10/2 and put it on a 25a breaker. My main area of concern is the thermostat. I see that both Honeywell and Marley 4 wire stats are only rated for 22amps. These are the two brands carried by my local supply house. Does it pose a risk to put the thermostat on a 25a or 30a breaker? Every house that Ive wired that was to be heated with electric, was tiny and only needed a couple circuits. Ive only done a handful of houses that needed electric heat in my 13 year career, so if there may be a better solution or product I'm all ears and appreciate the help.
