Amps
Electrical Contractor
- New Jersey
- Electrical, Security, Networks and Everything Else.
The owner is going to demo a concrete patio at the back of his house, install a new concrete patio, and have a spa placed a few feet from one edge of the patio.
The 50A circuit to power the spa is coming underground along the edge of the patio, then up a pressure treated 6x6, into the WP disconnect. The carflex load leads from the WP disconnect will go down the 6x6, be on top of the concrete, then into the spa's side for the internal connection. I am concerned about the carflex being a physical tripping hazard since there is a few feet of concrete "walkway" along the edge where the electric will be. The owner does not want the circuit set in the concrete under the spa in case they remove the spa someday, doesn't want any PVC sticking out of the concrete or a hole from it if it were cut off flush The house is about 8 feet from the spa with finished rooms in the basement. Main 100AMP panel is recessed in the wall of a finished room.
If the spa's WP disconnect was to be mounted on the house, it would be around the corner out of sight from anyone on the patio. I am also concerned about the 100AMP service, that has central air, electric cook top, wall oven and electric dryer. The spa's specs indicate 32A maximum current, 50A GFI rating. Owner objects to upgrading the service to 200A.
I attached a sketch for reference. Wondering if anyone has connected a spa this way and was it approved by the AHJ? The few I have done were on wood decks with access from below. Any thoughts or advice is very much appreciated. Thank you in advance.
